CB500V front brake master cylinder wanted
Vexx
Post by Vexx on Sun 05 May 2013, 8:22 pm
As it says, I need a replacement front brake master cylinder for my CB500v.
(That's the Brembo model)
The piston keeps sticking at the far end of it's travel - returning just far enough to result in no brakes affraid
Really not very helpful...
Jakliddle
Re: CB500V front brake master cylinder wanted
Post by Jakliddle on Sat 11 May 2013, 8:07 pm
Would you be interested in a front brembo calliper then here is a picture
as you can see it needs a clean nothing a bit of brake cleaner wont sort out if you are interested make me an offer Smile
Thanks, Jak
Vexx
Post by Vexx on Sun 12 May 2013, 10:44 am
appreciate the thought Smile but the caliper is ok, had it apart and serviced when I got the bike and replaced the (warped) front disc.
Cheers,
Vexx
Jakliddle
Post by Jakliddle on Sun 12 May 2013, 10:57 am
@Vexx wrote:appreciate the thought Smile but the caliper is ok, had it apart and serviced when I got the bike and replaced the (warped) front disc.
Cheers,
Vexx
Ok no probs Thanks Wink
Post by teamster1975 on Sun 12 May 2013, 12:04 pm
You'll probably find that you can refurbish the master cylinder with a rebuild kit, see here for kit.
It's not a hugely difficult job, only special tools you need are circlip pliers.
    Current date/time is Tue 17 Jul 2018, 7:56 pm
