cb500 97v fan,radiator and shocks
glen.wilson1@gmx.com
Post by glen.wilson1@gmx.com on Sun 24 Mar 2013, 4:23 pm
hi as the title suggests i really need a fan , radiator and
suspension shocks please if anyones breaking Very Happy
Nitesight
Re: cb500 97v fan,radiator and shocks
Post by Nitesight on Mon 25 Mar 2013, 12:16 am
There's a seller on eBay with Hagon shocks and a radiator fan
His name is kieran2875
Was looking at them today on my weekly browse for bits.
Post by glen.wilson1@gmx.com on Mon 25 Mar 2013, 8:32 am
@Nitesight wrote:There's a seller on eBay with Hagon shocks and a radiator fan
thanks mate ive seen that too im bidding on the fan so dont bid against me Laughing
i took my shock off yesterday wire brushed it and the top part painted with a rust paint, it seems to be working fine no leaks when pumped or bend rod. im going to try to save the shocks to save on cost, at least for now, im desperate for the fan and the radiator doesnt look great but ive never changed one, thats easy enough but if the radiator doesnt leak and the bike doesnt overheat is there anything else i should look for fault wise? the hangers broke and some of the fins are damaged but doesnt look a lot. Im going to take it off today after the shocks and take a good look.
Hario
Post by Hario on Mon 25 Mar 2013, 8:37 am
Shocks really loose their pazzaz over time, i rekon you would be much better off waiting a bit and buying some new ones
Post by glen.wilson1@gmx.com on Mon 25 Mar 2013, 7:32 pm
well ive had them off and gave them a good clean and they dont look too bad to be honest, they work as they should and the top where their rusting i brushed up and used a bit of rust primer and then hammerite and the top seems much more solid. If i get 12 months out of them then great, i just want to get it all running well
first then replace parts one by one rarther than everything at once! Very Happy
Post by badseeds on Mon 25 Mar 2013, 9:13 pm
@Hario wrote:Shocks really loose their pazzaz over time, i rekon you would be much better off waiting a bit and buying some new ones
+1. I've gone through two pairs of used shocks (about to fit a 3rd) in 9,000 miles.
Post by glen.wilson1@gmx.com on Mon 25 Mar 2013, 9:59 pm
wow, ive only ever took these off Laughing ive still a lot to learn i dont even know if mine are on the right setting i should research the best for me really. for now as long as they work that will do but i will check the settings, im guessing the further up the notches the firmer the suspension?
Post by ashcroc on Mon 25 Mar 2013, 11:02 pm
Depends what you mean by further up the notches. The more the spring is compressed the firmer the suspension. Wink
Post by Beresford on Tue 26 Mar 2013, 12:05 am
@ashcroc wrote:The more the spring is compressed the firmer the suspension. Wink
Adjusting the "notches" only has the effect of changing the ride height. The spring rate - "stiffness" doesn't change. The only way to stiffen the suspension ie. to make it firmer, is to change springs for ones of a higher rate.
Post by glen.wilson1@gmx.com on Tue 26 Mar 2013, 6:03 pm
thanks, shows how much i know lol, thats why i lve this forum! Very Happy
Post by glen.wilson1@gmx.com on Wed 27 Mar 2013, 7:48 pm
looks like the radiators going to need to be relplaced! Shocked
http://postimg.org/image/fu1ku1iw9/
http://postimg.org/image/wvuew4xrd/
savable?? Laughing
Vexx
Post by Vexx on Sun 05 May 2013, 8:14 pm
that looks sadly familiar - exactly where my radiator split, in rear bottom o/side corner Sad
Tried to braze it, but the rad alloy wasn't having any of it for some reason (even with ally friendly braze).
Ended up using JB Weld epoxy (rated to 500 deg C and lots of psi) as radiators in very short supply it seems and new Honda ones are £300 odd quid!!!
Anyway, the epoxy is holding just fine and should be a permanent repair Smile
Post by Tricky. on Sun 05 May 2013, 10:16 pm
did you manage to get a fan? ive got one if not.
Post by glen.wilson1@gmx.com on Mon 06 May 2013, 7:53 pm
@Tricky. wrote:did you manage to get a fan? ive got one if not.
thanks im all good now but thanks for the offer Very Happy
Post by Tricky. on Mon 06 May 2013, 8:48 pm
no problem pal Smile
    Current date/time is Tue 17 Jul 2018, 8:07 pm
