Camchain tensioner
highland twin
Camchain tensioner
Post by highland twin on Fri 08 Feb 2013, 8:51 pm
Had camchain tensioiner fitted today its now back to purring like a kitten, yeehaa !
ihowell
Re: Camchain tensioner
Post by ihowell on Sat 10 Oct 2015, 7:35 pm
how much did that cost you
Post by eternally_troubled on Sat 10 Oct 2015, 7:44 pm
A CCT normally costs about 60 quid, as I recall. You can fit it yourself, especially if your hands are small enough to get in behind the engine.
ihowell
Post by ihowell on Sat 10 Oct 2015, 10:16 pm
it is quite fiddly but i have managed to take it out, i was told that if you loosen the two bolts
and re tighten them up it stops the rattle i did this and after a few days the rattle returned.
Post by eternally_troubled on Sun 11 Oct 2015, 8:09 pm
Some people have tried taking it off and dunking it in a bucket of oil overnight then refitting to the bike: I'm not sure this works too well but it might be worth a go.
If all this fails you will have to replace it; it is a common failing of the CB500.
Post by Beresford on Sun 11 Oct 2015, 10:04 pm
Any more old failed CCTs out there not wanted ? I'll pay postage. I'd like to take a few more apart to see what the cause of failure is - whether it is always the same reason or not.
Post by Beresford on Sat 24 Oct 2015, 11:00 pm
BUMP
    Current date/time is Sat 23 Jun 2018, 1:44 am
